logging
i want to supervise my routers, if there is interfaces down.
it is possible to receive message from router when an interface is down.
if yes how can i do that plz.
Re: logging
You can enable Syslog logging using "logging " and make sure to have the command "logging event link-status" under the interfaces.
HTH,
Mohammed Mahmoud.
Re: logging
thanks Mohammed,
if you can tel me what difference between:
- snmp trap link-status
and
- logging event link-status
Re: logging
snmp trap link-status > sends snmp trap to the NMS for interface status.
logging event link-status > sends logging to a syslog server for interface status.
HTH,
Mohammed Mahmoud.
Silver
Re: logging
yoyo
if you have no syslog server, you can download a free one : http://www.kiwisyslog.com/index.php
but if you use subinterfaces with frame relay, may be you will not receive a log msg when only one lgical interface (and not the physical) comes down.
mohammed, did you face this problem before? i think in this case we must use SNMP traps.
Re: logging
Hi Oussama,
For subinterfaces you must make sure that the command "logging event subif-link-status" is under the main/physical interface.
HTH,
Mohammed Mahmoud.
Re: logging
thank you for your response,
another question plz,
there is possibility on router to send trap when time to ping a specific host exceed for exemple 100 ms?
160
