06-23-2012 12:42 AM - edited 03-07-2019 07:24 AM
Dear Friends,
While login cisco switch in exporter, some cisco switches are showing dash bord and some switches are not showing dash board.
even uploaded with same ios.
what could be the problem,
Just i need to get with dashboard
plz help me and find the attached file...on attached file both switches are updated with same IOS.
Srinivas. N.
06-23-2012 12:50 AM
Depends on HOW you uploaded the IOS.
If you just copied the BIN file then you're probably looking at an old HTML folder.
06-23-2012 12:57 AM
On attached file it is showing 2 cisco 2950 switches,
The same IOS uploaded to both switches via tftp server (boot system changed with new image)
when is type show version it is showing updated verson.
and both switch are opened in same explorer.
06-23-2012 09:23 AM
Srinivas. N.
Would you post the output of show version and of show flash from each of the two switches? This might give us more insight into the possible issue, and especially to the possibility that Leo raises that one switch may have been upgraded by doing copy the bin file to flash and the other switch may have been upgraded by using the tar file which creates a directory in flash that includes code for the GUI which provides the dashboard.
Rick
06-24-2012 12:36 AM
Hi Richard Burts,
Plz find both switches versons on below.
Note:- switch 1 is not showing dashobard and switch 2 is showing dashboard.
Switch 1
User Access Verification
Password:
GP_VIZAG_MAINSW_2950>en
Password:
GP_VIZAG_MAINSW_2950#sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA14, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2010 by cisco Systems, Inc.
Compiled Tue 26-Oct-10 10:35 by nburra
Image text-base: 0x80010000, data-base: 0x80570000
ROM: Bootstrap program is C2950 boot loader
GP_VIZAG_MAINSW_2950 uptime is 5 days, 7 hours, 11 minutes
System restarted at 05:55:24 IST Tue Jun 19 2012
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA14.bin"
cisco WS-C2950G-24-EI (RC32300) processor (revision K0) with 20956K bytes of mem
ory.
Processor board ID FOC0836Z05D
Last reset from system-reset
Running Enhanced Image
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:12:00:FE:D6:C0
Motherboard assembly number: 73-7280-05
Power supply part number: 34-0965-01
Motherboard serial number: FOC0835329Z
Power supply serial number: DAB0834EX4D
Model revision number: K0
Motherboard revision number: A0
Model number: WS-C2950G-24-EI
System serial number: FOC0836Z05D
Configuration register is 0xF
GP_VIZAG_MAINSW_2950#sh fla
GP_VIZAG_MAINSW_2950#sh flash:
Directory of flash:/
2 -rwx 110 Mar 01 1993 05:32:04 +05:30 info
3 -rwx 318 Mar 08 1993 13:54:59 +05:30 env_vars
4 -rwx 676 Mar 01 1993 05:30:18 +05:30 vlan.dat
5 -rwx 3132319 Mar 08 1993 13:53:47 +05:30 c2950-i6q4l2-mz.121-22.EA1
4.bin
6 -rwx 26 Jun 20 2012 12:29:03 +05:30 private-config.text
8 drwx 2688 Mar 01 1993 05:35:28 +05:30 html
90 -rwx 110 Mar 01 1993 05:35:29 +05:30 info.ver
91 -rwx 47 Jan 19 2009 18:21:25 +05:30 private-config.text.rename
d
92 -rwx 2974 Jan 19 2009 18:21:25 +05:30 config.text.renamed
93 -rwx 1048 Jun 20 2012 12:29:03 +05:30 multiple-fs
94 -rwx 3459 Jun 20 2012 12:29:03 +05:30 config.text
7741440 bytes total (1503744 bytes free)
Switch 2
Password:
NVVB_MAINSWITCH_2950>en
Password:
NVVB_MAINSWITCH_2950#sh ver
(fc1)
NVVB_MAINSWITCH_2950 uptime is 4 days, 10 hours, 55 minutes
ory.
Processor board ID FOC0836W3DB
Base ethernet MAC Address: 00:12:01:47:89:80
Motherboard serial number: FOC083626RP
Power supply serial number: PHI082504G7
System serial number: FOC0836W3DB
NVVB_MAINSWITCH_2950#sh flas
NVVB_MAINSWITCH_2950#sh flash:
2 -rwx 110 Mar 01 1993 00:56:54 +00:00 info
3 -rwx 318 Mar 06 1993 16:23:03 +00:00 env_vars
4 -rwx 736 Mar 01 1993 00:00:21 +00:00 vlan.dat
5 -rwx 3285 Mar 07 1993 12:56:29 +00:00 config.text
6 -rwx 5 Mar 01 1993 00:10:50 +00:00 private-config.text.rename
d
7 -rwx 3132319 Mar 06 1993 16:22:19 +00:00 c2950-i6q4l2-mz.121-22.EA1
4.bin
8 drwx 5632 Mar 01 1993 00:59:58 +00:00 html
90 -rwx 110 Mar 01 1993 01:01:29 +00:00 info.ver
92 -rwx 1048 Mar 07 1993 12:56:30 +00:00 multiple-fs
378 -rwx 856 Mar 01 1993 00:01:25 +00:00 vlan.dat.renamed
379 -rwx 2215 Mar 01 1993 00:10:50 +00:00 config.text.renamed
381 -rwx 25 Mar 07 1993 12:56:30 +00:00 private-config.text
7741440 bytes total (379904 bytes free)
06-24-2012 01:25 AM
Switch 1:
3132319 Mar 08 1993 13:53:47 +05:30 c2950-i6q4l2-mz.121-22.EA14.bin
Switch 2:
3132319 Mar 06 1993 16:22:19 +00:00 c2950-i6q4l2-mz.121-22.EA14.bin
Flash sizes for the HTML sub-directory don't match. The dates don't match either.
Just which method was used to upgrade the IOS? The copy-the-BIN-file or the recommended "archive download-sw"?
Based on the serial number of the switch, I would hazard a guess that the HTML files are based on the EA2 IOS (or earlier).
06-24-2012 01:25 AM
Srinivas. N.
Thank you for posting the information that I requested. It does confirm that both switches are running the same version of code. And it does confirm that both image files are in the root directory of flash and not in a sub-directory and so both were updated the same way. So that theory of the problem does not explain the difference in behavior.
I do notice a difference between the switches. Here is one of the directory listings from switch 1
and here is the corresponding directory listing from switch 2
The difference in size suggests that the HTML files on switch 2 are different from the html files in switch 1 and perhaps this explains the difference in behavior.
Rick
06-24-2012 02:20 PM
I upgraded all my switches (3)x 2950 this morning with the same version and they worked perfectly with dashboard... So i would reccomend reinstalling the ios on switch 1 and see if it works. And also the html file size should be around the same size as the other switches.! Let me know how it goes! All the best!
Note: make sure you verify the ios so you know its operational without andy issues
Warren
06-25-2012 11:40 AM
Before upgrading the ios also I noticed, Switch 1 was not showing the dashboard....
Both the switchs i upgraded in a same way....
Now how to get the dashboard in switch 1?
Srinivas. N.
06-24-2012 03:14 PM
3722814 May 13 2011 08:10:50 +10:00 c2950-i6k2l2q4-mz.121-22.EA14.bin
4416 May 13 2011 08:11:51 +10:00 html
Sorry, but I don't want to beat-a-dead-horse. This is taken from my few remaining 2950 family of switches with IOS EA14 running.
Observe the size of the HTML files. I upgraded the IOS using recommended "archive download-sw" automated command.
06-25-2012 12:14 PM
Hi Leolaohoo,
Thanks for repoly and my cisco 2950 switches having .bin fiel. But archive command todo with .tar,
won't it make it any problem....
fyi... last time by mistake for 2960 switch i upgraded the ios .tar file instead of .bin, then that switch had a problem.
again i upgraded the .bin through xmodem.
06-25-2012 03:35 PM
Ok, here's how you "fully" upgrade the IOS on a 2950 ...
Before we begin, I want to strongly emphasize that you must ensure that your 2950 doesn't loose power during the entire process ...
1. Delete the HTML files: delete /f /r flash:/html
2. Delete the IOS: delete /r /f flash:c2950-i6q4l2-mz.121-22.EA14.bin
3. Archive transfer the IOS to the switch: archive tar /x tftp://
NOTE: The command "archive download-sw" doesn't work for the 2950.
06-25-2012 11:56 AM
The dashboard is packed into the html files in the .tar file that has the ios,which is why you need to reimage it again to see if it had a conflict while transferring from the tftp server during the process.
