Looking for IOS c2900xl-h2s-mz-112.8.1-SA6.bin?
I''m trying to set up some VLAN's on an older WS-2924C-XL-A switch (trunking it with a newer 3750 core distribution switch).
Currently running the image:  c2900xl-h2-mz-112.8.1.SA6.bin      best I can determine looking at this version's release notes,
The Enterprise Edition release "c2900xl-h2s-mz-112.8.1-SA6.bin provides support for this capability, but I can't locate it anywhere
on Cisco's TAC web site.  Can anyone 1) Confirm this release will do what I need.   2) know where to locate/download it.
Not really concern about the level of support, just need to get it working.   I realize we may need to crack open our wallets here and
just replace the darn thing...
Any help would be appreciated!
Joe
Here is the show version info:
User Access Verification
Password:
SW9>enable
Password:
Password:
SW9#show ver
IOS (tm) C2900XL Software (C2900XL-H2-M), Version 11.2(8.1)SA6, MAINTENANCE INTE
RIM SOFTWARE
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Fri 14-May-99 17:39 by jchristy
Image text-base: 0x00003000, data-base: 0x0020CB34
ROM: Bootstrap program is C2900XL boot loader
SW9 uptime is 9 weeks, 2 days, 17 hours, 33 minutes
System restarted by power-on
System image file is "flash:c2900XL-h2-mz-112.8.1-SA6.bin", booted via show
cisco WS-C2924-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K byte
s of memory.
Processor board ID 0x0E, with hardware revision 0x01
Last reset from power-on
Processor is running Standard Edition Software
Cluster member switch capable
24 Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:D0:BA:10:04:40
Motherboard assembly number: 73-3382-06
Power supply part number: 34-0834-01
Motherboard serial number: FAA03229RF9
Power supply serial number: PHI031000UN
Model revision number: A0
Model number: WS-C2924-XL-A
System serial number: FAA0324H05S
Configuration register is 0xF
1 ACCEPTED SOLUTION
Purple
Re: Looking for IOS c2900xl-h2s-mz-112.8.1-SA6.bin?
  Here ya go , there is even some newer 12.X code for that seeing that you have a 8 meg box.  What you need is on the main cisco download page , must not have the correct  permissions .   Use the 12.X  code for your install , not the last 12.X release they made but its a lot newer than 11.X .
ftp://ftp.cisco.com/pub/lan/catalyst/2900XL/
VLANs and trunking should aready be supported on your current image.  The technique for adding a VLAN is slightly different from modern switches:
vlan database
  vlan 3 name VLAN003
  exit
You should also be aware that the old XL supported both encapsulations: dot1q and isl.  (Some very old images might support only ISL, but I think yours is OK.)  You therefore have to specify the switchport trunk encapsulation dot1q before you put the port into trunk mode.
Kevin Dorrell
Luxembourg
Purple
Ok.  Thanks for the info. What I've downloaded is c2900xl-c3hs-m.120-5.WC10.bin
Can I simply apply this using CNA 5.5 tool I'm now beginning to use to manage our cisco LAN switching environment?
Glen,
I  finally got around this weekend to updating 3 of our older 2924XL switches from 11.2 release to the 12.0.
I'm all set to go thanks to you!
The one mistake I made after transfering the .bin file to the local flash: drive was leaving off the "flash:" reference in my "set boot" command under "Config T".   When the switch rebooted, it was thrown into a local "switch:" prompt with an error that boot process failed.   After I realized from
the console in could locally boot using:     boot flash:c2900XLX-c3h2s-mz-120-5.3.WC.1.bin
It occured to me the "flash:" referene was missing.   So the next switch, I updated I used the following steps and it worked like a champ.
So the general steps were:
copy tftp:  flash:
specify... IP address of tftp server
specify... source file name
specify... destination file name
dir flash:        show display the IOS images on the local switch
config t
set boot flash:c2900XL-c3h2s-mz-120-5.3.WC.1.bin
ctrl-z
write mem
reload
Hereis a copy of the latest SHOW VERSION:
Password:
Password:
SW9>enable
Password:
SW9#show version
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5.3)WC(1), MAINTENANCE
INTERIM SOFTWARE
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 30-Apr-01 07:34 by devgoyal
Image text-base: 0x00003000, data-base: 0x003331F4
SW9 uptime is 36 minutes
System returned to ROM by reload
System image file is "flash:c2900XL-c3h2s-mz-120-5.3.WC.1.bin"
s of memory.
Processor board ID FAA0324H05S, with hardware revision 0x01
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
24 FastEthernet/IEEE 802.3 interface(s)
SW9#
What's interesting is I couldn't browse the Cisco software download section to find this older .bin file?
These switches are no longer under support, but why would Cisco hide these images from their customers...
Thanks again,
Joe
Hall of Fame Super Gold
How Glen found out about this FTP site is a wonder indeed.  And because it's not for general circulation you noticed that the directory is not really up-to-date.  You can still find the IOS for 1900, 2900XL/3500XL in the Cisco Download Centre.  The latest (and last) version for the 2900XL/3500XL is WC17.
Because the 2900XL has a very tiny flash, you don't need to specify the boot string.  The 2900XL can take only one IOS.
2253
