10-27-2013 07:15 AM - edited 03-07-2019 04:15 PM
One of our networks currently has a nexus 5548 acting as core. There are 2248/2232 connected to this as fex members.
There is also another nexus 5K connected as edge switch to this core.
We'r getting following messages on the core switch,
CORE_SW %$ VDC-1 %$ %FWM-2-STM_LOOP_DETECT: Loops detected in the network for mac dc5a.4d1e.5b0d
among ports Eth1/2 and Eth1/4 vlan 41 - Disabling dynamic learn notifications for 180 seconds
CORE_SW %$ VDC-1 %$ %FWM-2-STM_LEARNING_RE_ENABLE: Re enabling dynamic learning on all interfaces
Appreciate help on this errors.
Thanks in advance.
10-27-2013 08:03 AM
Is the edge 5500 connected to the core 5500 via 2 links (e1/2 and e1/4 vlan 41)?
Is spanning tree configured on the switches?
Can you post relavent configs from both 5ks?
10-27-2013 09:46 AM
Thanks Reza for the reply.
The edge 5500 is connected to Nexus Core 5500 via port-channel.
We haven't configured any spanning tree commands specifically on the switches, hence i believe it should just be the default ones.
I do not hold access to these as of now. If you can let me know what outputs you need & what to check with commands, i'll request it from our subsidary owning the network.
Appreciate your kind assistance.
10-27-2013 02:01 PM
Can you post
Sh spann vla 41
Sh run spanning
Sh po summ
Are both physical ports are up and up as part of the po?
What interfaces are in the po?
10-29-2013 01:48 AM
edge-5500 is connected to Core-5500 via e1/25 & e1/26 using Po50
interface Ethernet1/25
switchport mode trunk
channel-group 50 mode active
interface Ethernet1/26
interface port-channel50
description Etherchannel to edge-5500
CORE_SW_1# sh spanning-tree vla 41
VLAN0041
Spanning tree enabled protocol rstp
Root ID Priority 32778
Address 002a.6a34.8401
Cost 3
Port 133 (Ethernet1/5)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32829 (priority 32768 sys-id-ext 61)
Address 002a.6a39.8b41
Interface Role Sts Cost Prio.Nbr Type
Po50 Desg FWD 1 128.4145 P2p
Eth1/2 Desg FWD 2 128.130 P2p
Eth1/5 Root FWD 2 128.133 P2p
Eth1/6 Altn BLK 2 128.134 P2p
Eth1/10 Desg FWD 2 128.138 P2p
Eth101/1/1 Desg FWD 4 128.1153 Edge P2p
Eth101/1/2 Desg FWD 4 128.1154 Edge P2p
Eth101/1/8 Desg FWD 19 128.1160 Edge P2p
Eth101/1/9 Desg FWD 4 128.1161 Edge P2p
Eth101/1/10 Desg FWD 4 128.1162 Edge P2p
Eth101/1/11 Desg FWD 19 128.1163 Edge P2p
Eth101/1/13 Desg FWD 4 128.1165 Edge P2p
Eth101/1/14 Desg FWD 4 128.1166 Edge P2p
Eth101/1/16 Desg FWD 4 128.1168 Edge P2p
Output of sh run spanni:
interface Ethernet1/1
spanning-tree port type edge
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet101/1/1
interface Ethernet101/1/2
interface Ethernet101/1/3
interface Ethernet101/1/4
interface Ethernet101/1/5
interface Ethernet101/1/6
interface Ethernet101/1/7
interface Ethernet101/1/8
interface Ethernet101/1/9
interface Ethernet101/1/10
interface Ethernet101/1/11
interface Ethernet101/1/12
interface Ethernet101/1/13
interface Ethernet101/1/14
interface Ethernet101/1/15
interface Ethernet101/1/16
interface Ethernet101/1/17
interface Ethernet101/1/18
interface Ethernet101/1/19
interface Ethernet101/1/20
interface Ethernet101/1/21
interface Ethernet101/1/22
interface Ethernet101/1/23
interface Ethernet101/1/24
interface Ethernet101/1/25
interface Ethernet101/1/26
interface Ethernet101/1/27
interface Ethernet101/1/28
interface Ethernet101/1/29
interface Ethernet101/1/30
interface Ethernet101/1/31
interface Ethernet101/1/32
interface Ethernet101/1/33
interface Ethernet101/1/34
interface Ethernet101/1/35
interface Ethernet101/1/36
interface Ethernet101/1/37
interface Ethernet101/1/38
interface Ethernet101/1/39
interface Ethernet101/1/40
CORE_SW_1#sh port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
S - Switched R - Routed
U - Up (port-channel)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
40 Po40(RU) Eth NONE Eth1/17(P) Eth1/18(P)
50 Po50(SU) Eth LACP Eth1/25(P) Eth1/26(P)
101 Po101(SU) Eth NONE Eth1/27(P) Eth1/28(P)
102 Po102(SU) Eth NONE Eth1/29(P) Eth1/30(P)
103 Po103(SU) Eth NONE Eth1/31(P) Eth1/32(P)
CORE_SW_2# sh spanning-tree vla 41
VLAN0041
Cost 4
Port 4145 (port-channel50)
Po50 Root FWD 1 128.4145 P2p
Please help with suggestions. Thanks.
