Loopback Interface IP Address
Dear All,
Can i use loopback interface without assign ip address to it??
i want to use it for NAT on stick
With Regards
Hall of Fame Super Silver
You certainly can configure a loopback interface and not give it an IP address. I am puzzled at how you would use it for NAT on stick without it having an address.
Rick
Re: Loopback Interface IP Address
Can I assign any ip for loopback interface and not related to ip that using in NAT
VIP Super Bronze
Sure, you can assign any available IP address to a loopback interface, as long as that IP is not used anywhere else in your network.
example:
int lo0
ip address 172.16.1.1 255.255.255.255
or
int lo0
ip address 10.10.10.1 255.255.255.255
I want to use NAT on stick to complete static NAT in router that have only one physical interface , please confirm that assign any ip to loopback interface will not effect on NAT process
Hello.
I guess it would be better if you provided some diagram and description what you are configuring.
But I would say that static NAT translations may use ip-addresses that are not assigned to any router's interface.
Kindly note diagram
With Thanks
168
