08-02-2010 02:05 AM - edited 03-06-2019 12:16 PM
I want to know why do not have MAC address on loopback interface on Router or Switch??
If I see on useing #show int loopback 0
There is no MAC address.
If these are not support the MAC address then it's only depend on IP even on WAN area??
Please your helpful reply require..
Solved! Go to Solution.
08-02-2010 11:03 AM
Let us start the explanation by reviewing a fundamental concept about MAC address. The purpose of a MAC address is to distinguish individual devices on the media (it is a link local layer 2 address).
Since the loopback interface is by definition not connected on any physical media there is no purpose in a link local address and MAC addresses are not supported on loopback interfaces.
Rick
08-02-2010 08:40 PM
Yes, the ping is via the IP addresses and IP routing. There is no
encapsulation required for that.
NT
08-03-2010 04:09 AM
Encapsulation is how you build a header for a particular physical media. Since there is no physical media associated with a loopback interface there is no encapsulation associated with a loopback interface.
Rick
08-02-2010 06:42 AM
Loopback interfaces are virtual interfaces created in software by the router/switch. Unlike other virtual interfaces, the loopback interface will not have any physical connectivity with another device. Whoever needs to communicate with the loopback interface need to go through another physical interface enabled with IP routing. So, communication between that physical interface and the loopback interface happens in software (no need of MAC). Hence you do not need a MAC address for the loopback interface.
Hope this helps.
NT
08-02-2010 11:03 AM
Rick
08-02-2010 08:35 PM
If Router A have loopback and Router B is can ping to loopback int. of Router A, so only on basis of IP address ping to same??
any idea abour encapsulation loopback??
08-02-2010 08:40 PM
NT
08-03-2010 04:09 AM
Rick
07-31-2023 05:32 AM
Loopback Interface Will Use The MAC Address Of First Interface Of The Router/Switch
07-31-2023 12:48 PM
Just curious, you would see this where (being done)?
07-31-2023 01:33 PM
I'm sure its implementation dependent as Harold mentions but we had a thread earlier today that shed some light from a different question.
https://community.cisco.com/t5/ipv6/loopback-interface-eui-64/m-p/4896288#M4866
07-31-2023 01:56 PM
Ah, interesting, but might there also be different behavior between IPv4 and v6?
07-31-2023 02:02 PM
I believe so. I would have to lab up later but possibly uses the exit interface MAC when encapsulating the packet if it has one (not serial interface)
07-31-2023 04:09 PM
Hi @David Ruess ,
To put this in context, the MAC address is used to derived the EUI-64 host identifier when the loopback interface is configured with an ipv6 address using the eui-64 keyword. This has nothing to do with the MAC address that traffic originating from the loopback will use.
07-31-2023 04:48 PM
Gotcha. Thanks for the clarification. I never questioned it or ever even noticed a Loopback didn't have a MAC except for IPv6 configuration. I definitely made some assumptions about the question asked that I will go back and check in my lab to help me understand.
