Community Member
Loopguard blocking single feed port on Cisco 3750
Loopguard on a 3750 is blocking the single feed port several times a day. My question is why? Could a hub be connected to the switch with a loop on the hub? I would then think the port with the hub would be blocked not the feed port to the rest of the network.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Loopguard blocking single feed port on Cisco 3750
Hello Randy,
loop guard is triggered by the missing of superior BPDUs received on the link.
Instead of promoting the port to Designated Port on the segment the port is placed in STP inconsistent state.
This behaviour is Vlan specific.
see example of messages I got on one of our devices
sh log | inc Jan 28
Jan 28 00:33:19: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port GigabitEthernet0/28 on VLAN0001.
Jan 28 00:33:19: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port GigabitEthernet0/28 on VLAN0001.
Jan 28 08:12:27: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port GigabitEthernet0/28 on VLAN0001.
Jan 28 08:12:28: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port GigabitEthernet0/28 on VLAN0001.
Jan 28 09:40:03: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port GigabitEthernet0/28 on VLAN0001.
Jan 28 09:40:03: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port GigabitEthernet0/28 on VLAN0001.
to be noted g0/28 is the root port for vlan1
sh spanning-tree vlan 1
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 1
Address 0017.0fad.1900
Cost 4
Port 28 (GigabitEthernet0/28)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 0023.0419.2680
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Gi0/27 Altn BLK 4 128.27 P2p
Gi0/28 Root FWD 4 128.28 P2p
Po1 Desg FWD 3 128.56 P2p
sh spanning-tree interface g0/28 det
Port 28 (GigabitEthernet0/28) of VLAN0001 is root forwarding
Port path cost 4, Port priority 128, Port Identifier 128.28.
Designated root has priority 1, address 0017.0fad.1900
Designated bridge has priority 1, address 0017.0fad.1900
Designated port id is 128.8, designated path cost 0
Timers: message age 15, forward delay 0, hold 0
Number of transitions to forwarding state: 27
Link type is point-to-point by default
Loop guard is enabled on the port
BPDU: sent 78, received 587997
the port receives BPDUs from the root bridge on g0/28 if it misses to receive them (three in a row) it triggers the STP loop guard and instead of trying to put in forwarding the port it moves to inconsistent state.
In our scenario there are two uplinks and core switches are root bridge for different vlans.
However, if this is the only uplink of the switch you could consider to disable loop guard and to have bpu guard configured on all the access ports. This should be enough.
Hope to help
Giuseppe
Can u please elaborate more,we r not able to understand u topology.
Mahmood
Hello Randy,
sh log | inc Jan 28
VLAN0001
Root ID Priority 1
Cost 4
Aging Time 300
Hope to help
Giuseppe
1572
