09-23-2017 08:38 AM - edited 03-08-2019 12:08 PM
On a stack of three SG500-X 24P for apparently no reason im loosing suddently the intervlan routing.
Nothing relevant in the logs.
Firmware 1.4.7.6
show ip route commands says...
Before reboot :
C 10.22.56.0/24 is directly connected, vlan 2256 C 172.16.0.0/16 is directly connected, vlan 2252 C 172.20.230.0/24 is directly connected, vlan 2253
After reboot
C 10.22.56.0/24 is directly connected, vlan 2256 C 172.16.0.0/16 is directly connected, vlan 2252 C 172.20.0.0/24 is directly connected, vlan 2251 C 172.20.230.0/24 is directly connected, vlan 2253
Do you have any clue of what could be the cause ?
Solved! Go to Solution.
09-23-2017 11:34 AM
09-23-2017 09:20 AM
latest firmware is 1.4.8.06, upgrade to that and see if the problem persists. Also, if you are using macros, that might mess with your configuration. Try and disable macros globally by using the global config command 'no macro auto'...
09-23-2017 11:34 AM
10-18-2017 07:39 AM
10-18-2017 08:39 AM
The first thing you want to do with these small business switches is upgrade the firmware. That usually solves most problems...
