Silver
Lost console access in 6506
Guys,
While almost finishing configuration on 6506, I lost console connection, now every time I tried to access to console, it asks for username which is not yet created.
Do I need to do password recovery ?
if yes, then I don't see break/pause key in my dell inspiron 1545 which is required to break the booting sequence in Secure CRT.
Please help
Posted by WebUser Pushpendra Yadav from Cisco Support Community App
Hall of Fame Super Silver
It is not clear to me from your description of the problem whether password recovery is required. But it is probably a good assumption that it may be.
I have faced the issue of now having a break key on the keyboard of my Dell laptop. I found that the solution was to map a key in SecureCrt that will send the break signal.
Rick
Silver
Issue resolved, I wasn't able to go to Rommon Mode
then I pressed escape (I think, cause I press lot of keys as I was bit P** off) then I was in SP more( Switch Processor)
I erased my startup config(it is a new setup and I had copy of config) and then reset it back,
Everything is normal. phew.
I am glad that you were able to resolve your issue. Thank you for posting back to the forum to inform us that you have resolved it.
Rick
147
