Low end Router with 3 Fast ethernet ports
Hi all,
Can someone tell me the cheap wan router with 3 fast ethernet ports?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Hi Mahesh,
If you don't have any more issues, can you please mark this thread as "Answered"?
(Don't worry.  Marking this thread as "Answered" won't cost you anything.)
Silver
mahesh18 wrote:
Hi all,
Define "cheap".
What kind of throughput do you want? What kind of WAN is going to be connected (xDSL, Cable, leased line, frame relay)?
For a typical home DSL installation, you can get by with an 887, but for nowhere near as cheap as, say, a Linksys or Billion or DLink consumer grade device.
Define "3 fastethernet ports"?
Do you want 3 Layer 2 only ports (with or without PoE) or 3 Layer 3 ports?
Hi all,
currently i have router with 2 fast ethernet ports
1 port connects to cable modem.
Other has connection to layer 3 switch.
I am running HSRP  on 2 layer 3 switches.
But i have single connection from layer 3 switch to Router port.
I need router with  3 ports so that 2 ports can connect to 2 layer 3 switches.
Currently port that connects layer 3 switch to router is routed port.
Thats the reason i am looking for Router with 3 fast ethernet ports.
mahesh
Re: Low end Router with 3 Fast ethernet ports
If you want want Layer 2 only ports, then the 860 and 880 are starters.
If you want Layer 3 ports then 1900 ISR G2 has two routable FE ports, you just need to get an HWIC-1FE to make it the 3rd routable FE ports.
Hi Leolaohoo,
Thanks for reply.
I currently  have 2650 XM  router.
Can you tell if if i can buy single fastethernet module so that i can add to existing router?
is this possible to upgrade the 2650xm router to 3 FE  ports?
thanks
mahesh
Hi Mahesh,
Hi Leolaohoo,
Thanks for the help.
I will buy 1 FE  module for my existing router.That will solve my problem.
Sorry for the late reply.
Sincerely
Mahesh
Thanks Mahesh.
2359
