low on mem? i think?
jason.young4
hello i am a total newb and am having trouble with a lan. i have posted this on another site but nobody seems to know the trouble. here is the link... please can someone point me in the right direction. thanks
http://www.networking-forum.com/viewtopic.php?t=1676
15 Replies 15
jason.young4
can anyone help please?
Hi Jason
Can you check out show process cpu command and find out which process hogs your CPU.
Also another alternate would be going on for a upgrade to a later version of ios on your router.
You can think of doing the same once you have enough DRAM and FLASH on your router to do so..
regds
It sounds like an IOS bug relating to NAT memory usage. I'm sure I"ve heard of one recently.
Which version of IOS are you running? Can you upgrade to the latest?
ok here is the deal. I had a buddy reconfig it (mainly because i dont know how) but still same issue. Also I believe its 12.3, here is what it is saying:
-Process= "IP Input", ipl= 0, pid= 33CHUNKEXPANDFAIL: Could not expand chu
-Traceback= 80281980 802834BC 802937D0 80292AE4 80294A74 80292948 80AA7C64 80AA8
*Jul 12 17:26:36.754: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ip
nat node. No memory available
-Process= "Chunk Manager", ipl= 5, pid= 1
-Traceback= 802927D0 80276AD8 8027B0E8
*Jul 12 17:26:46.814: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ip
*Jul 12 17:26:50.650: %SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed
from 0x802937CC, alignment 8
Pool: Processor Free: 12376 Cause: Not enough free memory
Alternate Pool: I/O Free: 6548 Cause: Not enough free memory
ED4 80AA9604 80AAAA60 80AA75F0 80441E58 80440954 80440B24 80440CF0 80276AD8
%% Low on memory; try again later
Which version of 12.3? Whats 'show version' list the filename/version as?
ahmednaas
Level 4
Level 4
Can you post the results of sh version on the router?
i dont know what version i had before lastnight but I updated it to 12.3(8)T. I am going to check it this morning and see how its working!
ok same thing... i am thinking its a bad stick of mem.. or bad memory...damnit to hell!
Can't you run a 12.4T image?
because I don't believe sisco will provide me the update because 1721 is no longer supported... can you email it to me.
Is the 12.3 IOS version you're running the latest release in the 12.3 train that you can run?
to be honest i couldnt tell you because i am a newb.. can you point me in the right direction?
Assuming you have a CCO login:
* Log into the cisco.com website
* On the right hand side should be a dropdown box labelled "Download software". Select IOS Software
* Click on IOS 12.4 software
* Click on Download Software
* This should launch the IOS upgrade planner which lets you browse software based on version, platform, release and features.
Take a look at that.
I dont have CCO login.. i dont know how to get it.. I tried but wont let me..i think
