low speed connection between 2970 against 2 2950 switches
Dear all,
I need help in order to find out way when i run a test iperf.exe betwwen 2 pc's that connects one to switch A 2950 and the other connects to switchB 2950 and boths switches are connected to 2970, with up link on trunk ports at 1000 mbits and full duplex , and i getting rates about 2.5mbits por seconds , means to low.
here my actual config on port of each switches:
Im attaching .txt with actual configs
Core switch 2970
interface Giga 0/1 - Switch 2950A gigaport 0/1
interface giga 0/2 - switch 2950B gigaport 0/1
Switch A
interface fe 0/39 PC1
switchB
interface fe 0/39 PC2
hope this helps
Re: low speed connection between 2970 against 2 2950 switches
I'm not really sure if the attached config is the right one ;-), but I have an idea. We have trouble when the port is fixed to 100/Full for example and the PC card is auto-deteced. Because the autonegotiation process is not working and the connections is really but and maybe not working.
Sebastian
Well , finaly i have found the solution updating the ios.
thanks anyways
113
