Community Member
Lowest cost 48 port switch with support for full PoE 15w
We're trying to analyze options for a new deployment of 7965 phones (which use 15w each). So using the power calc tool, I was able to find a few switches that can fully support all 48 ports with 15w.
My question is which would be the lowest cost option?
Thanks..
1 ACCEPTED SOLUTION
Re: Lowest cost 48 port switch with support for full PoE 15w
Shane,
Do you need power on all 48 ports? or more than 24? Here are the lowest cost switches that should suit your needs.
24 or less phones WS-C3560-48PS
25 - 48 phones WS-C3560E-48PD1150W
HTH,
Mark
1 REPLY
Shane,
HTH,
Mark
163
