Lucent Portmaster Config
Hi Guys,
getting my CCIE lab together and i got my hands on a Lucent Portmaster for terminal Server Access. It's working fine, i can Reverse telnet etc... butone thin i don;t know how to do is exit form a session after i have logged in. ctrl+alt+6 & x will not work.
Does anyone know?
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
1 REPLY
Silver
Re: Lucent Portmaster Config
: Terminating Active Sessions
To terminate a particular Telnet session:
Suspend/escape from the current session. To suspend a Telnet session, enter the escape
sequence Ctrl-Shift-6-x.
Note: Ensure that you can reliably issue the escape sequence to suspend a Telnet session.
Some terminal emulator packages have difficulty sending the correct sequence,
Ctrl-Shift-6, x.
Display all open connections using the show sessions command.
Disconnect the desired session using the disconnect [connection] command.
330
