MAC ACL on 3750 switch
bryantsteve
On c3750 switch running 12.2(55)SE2,  as an alternate to static port security I'm trying to use  MAC acl on a group of switch ports in a lab area where users need to be able to move around to different ports. ACL looks like this:
Extended mac accesslist lab
permit host <mac address#1> any
permit host <mac address#2> any
permit host <mac address#3> any
etc
deny any any
and applied to desired ports
interface g1/0/18
mac access-group lab in
As far as I can tell the acl has no effect in filtering  mac addresses either to permit or deny.  What am I missing?
cadet alain
MAC ACL will only work for non IP traffic.
Regards.
Alain
7 Replies 7
cadet alain
Regards.
Alain
I looked at the command ref link you posted and I don't see it.  Am I missing something?  In fact, the mac access-list extended command has a protocol argument, and one of the valid values is ip.
Yes I see where you mean, I believe the thing is in the doc  there is first a description  of a  mac acl <700-799> which is available as an option on switches running in layer 3 IP routing mode ,then followed by mac access-list extended, which for what ever reason will only filter non-IP traffic. My  3750 switch  is running IP Base IOS code at layer 2 and the only command option I'm seeing  in that mode for mac acls is the mac access-list extended.
The capability of MAC ACLs to filter IP traffic depends very strongly on the particular platform. The link Alain posted is taken from the general IOS documentation and not from the documentation related to a particular switch. However, if looking specifically on 3750, this are the appropriate documents:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/15.0_2_se/configuration/guide/swacl.html#wp1289037
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/15.0_2_se/command/reference/cli1.html#wp11902410
Both stress that MAC ACLs are for non-IPv4 traffic.
Best regards,
Peter
Ok, I see the first line in the config guide says ""You can filter non-IPv4 traffic on a VLAN or on a Layer 2 interface" (does this imply you CAN filter IPv6?).
Thanks for the clarification Peter.
You are welcome!
Yes, that is my understanding although I haven't tested it personally yet.
Best regards,
Peter
