mac acl on native vlan (trunk port)?
Hi there
How can this be achieved?
E.g. an MAC-ACL on a trunk where an accesspoint is connected. So, that only a defined MAC (AP) is allowed to connect through the native VLAN.
Norbert
1 ACCEPTED SOLUTION
Purple
you can configure port-security on a trunk port per vlan but the port must be an unconditional port( the output from operational and administrative mode must be trunk in sh int switchport command).
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_20_ea2/configuration/guide/swtrafc.html#wp1038552
Regards.
Alain
Purple
you can't use a MAC ACL as it only works for non IP traffic but you  can use port security( for Vlan 1) as long as the port is an unconditional trunk( switchport mode trunk).
Regards.
Alain
Re: mac acl on native vlan (trunk port)?
Thanks for the reply.
I'll get a try on my lab, but I've found this.
..Cisco does not allow you to configure port security in trunk ports cause trunk ports may learn many mac addresses which will defeat the use of port security feature...
Greets,
Norbert
Purple
Regards.
Alain
I tried the configuration on a trunk port with an access point. The problem is, that the roaming doesn't work with a couple of access points.
Greets,
Norbert
288
