04-24-2007 07:02 AM - edited 03-05-2019 03:39 PM
Hi all,
We have a 1721 box configured with a Vlan, two ports added to this Vlan. I wonder how to know what mac address is linked to fas1 and what mac address is linked to fas2. I have been trying lots of commands getting just informacion about the vlan but not about the ports.
thx in advance
04-24-2007 07:07 AM
Hi Enriq,
I believe you have ether switch modules installed on 1721 box? If yes you can issue a command "sh int fa1/1 and sh int fa1/2"
Ankur
04-24-2007 07:18 AM
Hi Ankur,
Yes, I have a switch module, but what I wanna get are the mac addresses dynamically cached in each port. Until now all commands say that are learned via Vlan901 without give any further information about ports.
04-24-2007 07:23 AM
Hi Enriq,
So you will like to know the mac address learned dynamically on all ports like you get on any catalyst switches correct?
If yes you can issue a command "sh mac-address-table dynamic"
Also check this link if you are looking for some configuration guide and show commands available on ether switch module
Ankur
*Pls rate all helpfull post
04-24-2007 07:26 AM
Well, the Wic is a 4-port and the sh mac-add tab command is not supported in the 1721 box.
04-24-2007 08:17 AM
Hi Enriq,
I found out that MAC address table commands are not available on WIC-4ESW and its a platform limitation.
Ankur
04-24-2007 11:35 AM
Hi there,
Just out of curiosity won't the "show arp" have it?
BR,
Mohammed Mahmoud.
04-24-2007 12:18 PM
Hi!
I have tried that command, don't shows anything. sh ip arp shows mac addresses but don't give informacion about the port, just about the vlan.
thanks
04-25-2007 01:27 AM
Hi all,
Finally I have the answer, sh controllers is the command. Here is the relevant output:
Mac Address | Ports | Entry State
00-00-00-00-00-00 | 0x20 | 0x0D
00-14-38-C9-7E-0A | 0x04 | 0x0E
00-16-46-D9-AE-0D | 0x20 | 0x0F
00-16-47-46-DC-14 | 0x20 | 0x0E
00-16-47-46-DC-15 | 0x20 | 0x0E
00-16-47-46-DC-16 | 0x20 | 0x0E
00-16-47-46-DC-17 | 0x20 | 0x0E
00-80-9F-5D-A8-5E | 0x01 | 0x0D
00-80-9F-5D-A8-80 | 0x02 | 0x0E
01-00-0C-CC-CC-CC | 0x20 | 0x0E
01-00-0C-CC-CC-CD | 0x20 | 0x0E
I can see the macs learned in ports 1, 2 and 4.
