Community Member
MAC address
I have 2948 switch running CatOS 6.3.7. One device is connected to the switch port and the port is showning connected, however we can not see the mac address of the device. Any idea how to find out the MAC address of this device..
Switch> (enable) sh cam dynamic 2/21
* = Static Entry. + = Permanent Entry. # = System Entry. R = Router Entry.
X = Port Security Entry $ = Dot1x Security Entry
VLAN Dest MAC/Route Des [CoS] Destination Ports or VCs / [Protocol Type]
Total Matching CAM Entries Displayed =0
Switch> (enable) sh cam stat 2/21
Switch> (enable) sh port 2/21
Port Name Status Vlan Level Duplex Speed Type
2/21 Protego connected 5 normal a-full a-100 10/100BaseTX
Port AuxiliaryVlan AuxVlan-Status InlinePowered PowerAllocated
Admin Oper Detected mWatt mA @51V
2/21 none none - - - - -
Port Security Violation Shutdown-Time Age-Time Max-Addr Trap IfIndex
2/21 disabled shutdown 0 0 1 disabled 29
Port Num-Addr Secure-Src-Addr Age-Left Last-Src-Addr Shutdown/Time-Left
2/21 0 - - - - -
Port Status Channel Admin Ch
Mode Group Id
2/21 connected off 86 0
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
2/21 - 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
2/21 0 0 0 0 0 0 0
Last-Time-Cleared
Tue Apr 17 2007, 12:20:50
Community Member
Re: MAC address
Does the device have an IP address already? If it does do a show arp | inc or you can go to the actual device and get the mac address ipaddress/all if its a windows box.
Community Member
Re: MAC address
No IP address, it's March device and we are trying to find its IP address using its MAC..
Hall of Fame Super Gold
Re: MAC address
Ahmed
From the fact that there is no entry in the CAM I am assuming that it has been longer than the CAM aging time since the device has sent any frame. If you could get the device to send a frame then its MAC address should get added to the table. Perhaps if you disable and then enable the port (drop link and bring it back up) it would get the device to send a frame (or disconnect its cable and reconnect).
Rick
Silver
Re: MAC address
I have seen this with some of my IBM OSA devices. Either recycle the port (SET PORT DISABLE/ENABLE) or the device needs to be reinitialized. The connected status is just a layer one link that is seen. The MAC is not coming across probably because the device needs to initialize traffic or be reset....Good Luck...
148
