Bronze
MAC Flaps on Ports to WLC
All, got some MAC Flapping errors below on our Core switch -
%SW_MATM-4-MACFLAP_NOTIF: Host xxx.xxx.xxx in vlan 1 is flapping between port Gi1/0/4 and port Gi2/0/16
I get the same error for different MACs / VLAN but always the same 2 ports - Gi1/0/4 and Gi2/0/16.
These two ports connect back to our WLC 5505.
Any ideas on why the WLC links are showing MAC Flaps?
CDP from the core shows the WLC ports used.
WLC-01    Gig 1/0/4         177               H    AIR-CT550 LAGInterface0/3/1
WLC--01    Gig 2/0/16        177               H    AIR-CT550 Gig 0/0/2
Re: MAC Flaps on Ports to WLC
Can you check to ensure you have LAG enabled on the WLC?
Also, can you check the switch to ensure ports Gi1/0/4 and Gi2/0/16 are part of the same Port channel group?
Possibly post configs of the switch interfaces and the portchannel interface.
Sounds to me like a portchannel is not forming between the switch and the WLC so the switch is recieving frames with the same source MAC from both interfaces and it can't handle this if they are not part of a portchannel.
Bronze
The ports on the Core (Gi1/0/4) and (Gi2/0/16) are not in any sort of Port Channel They are just acting as individual ports.
I assume they should form an etherchannel. This is fine, I can configure this.
On the WLC itself - how can i check if the ports are enabled for LAG. Commands seem to be a bit different on the WLC IOS.
HI ,
Please issue the command show interface summary and see the interface is in LAG mode or not .
eg
Interface Name        Port  Vlan Id   IP Address       Type     Ap Mgr
ap-manager            LAG   15        x.x.x.x           Static   Yes
It says the port is in LAG or not
Bronze
Hi There,
So running command shows
x                  LAG  471      x.x.x.x     Dynamic No     No
y                  LAG  472      x.x.x.x   Dynamic No     No
z                  LAG  473      x.x.x.x     Dynamic No     No
management                       LAG  untagged x.x.x.x    Static  Yes    No
redundancy-management            LAG  untagged 0.0.0.0         Static  No     No
redundancy-port                  -    untagged 0.0.0.0         Static  No     No
service-port                     N/A  N/A      192.168.1.1     Static  No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
Although I'm not sure which of these corresponds to the WLC ports -
LAGInterface0/3/1
AIR-CT550 Gig 0/0/2
350
