macro description cisco-desktop question???
Hi, my question is about the use of the command macro description cisco-desktop.
What are the benefits os using this command?
This command can be apply on a dynamic port?
Should I apply security commands on a port ti use this command???
Thanks a lot
Regrads
Lp
1 REPLY
Re: macro description cisco-desktop question???
Are you talking about macro global description command ??
If thats the case do refer this link for more info..
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_31s/cmdref/int_sess.htm#wp2097159
regds
887
