Community Member
Major/Minor Error on 6509 switch
We have two cisco 6509E switches which are configured in VSS mode. The status of one of the two supervisor engines (
Supervisor Engine 2T) is Major failure as follow:
B1CS05A#sh mod
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6848-GE-TX     SAL1644RGZC
  2    8  DCEF2T 8 port 10GE                     WS-X6908-10G       SAL1643QYRY
  3    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1518CXL4
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G       SAL1643R24T
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  6c20.56c3.2640 to 6c20.56c3.266f   1.0   12.2(18r)S1  15.0(1)SY2   Ok
  2  001f.6ca4.a1f0 to 001f.6ca4.a1f7   1.2   12.2(50r)SYL 15.0(1)SY2   Ok
  3  c471.febe.7d74 to c471.febe.7d77   3.2   12.2(14r)S5  15.0(1)SY2   Ok
  5  e05f.b911.5acd to e05f.b911.5ad4   1.3   12.2(50r)SYS 15.0(1)SY2   MajFail
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Distributed Forwarding Card WS-F6K-DFC4-A      SAL1644R94K  1.2    Ok
  2  Distributed Forwarding Card WS-F6K-DFC4-E      SAL1638MZ88  1.2    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       SAL1518D0W3  4.1    Ok
  5  Policy Feature Card 4       VS-F6K-PFC4        SAL1642PYZK  1.2    MajFail
  5  CPU Daughterboard           VS-F6K-MSFC5       SAL1643R1SK  1.4    MajFail
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  5  Major Error
When I reset the module, the status converted to "Minor Error"!!
Switch Number:     1   Role:   Virtual Switch Active
  5  e05f.b911.5acd to e05f.b911.5ad4   1.3   12.2(50r)SYS 15.0(1)SY2   Ok
  5  Policy Feature Card 4       VS-F6K-PFC4        SAL1642PYZK  1.2    Ok
  5  CPU Daughterboard           VS-F6K-MSFC5       SAL1643R1SK  1.4    Ok
  1  Pass
  2  Pass
  3  Pass
  5  Minor Error
Attached is Show diaganostic and show enviroment for the switch. What should I do to solve that issue?
Re:Major/Minor Error on 6509 switch
Your best bet is to open a TAC case. They've seen errors like this whereas most of us have not.
Sent from Cisco Technical Support Android App
Purple
  You will probably have to get that Sup replaced.
Silver
Before going straight up for the RMA you may want to configure the following:
conf t
diagnostic bootup level complete
exit
Then reseat the supervisor by pulling it out and then back in into the chassis, once it runs the complete diagnostics and comes back up, check to see if the minor error still there in show module output, check the logs for any errors. finally do the show diagnostics result module 5 to see what test was the one that failed. It may be due to a parity error that can be recover with a hard reset, and as a last option go for the replacement.
Hope this helps.
Community Member
Thanks for the reply.
But the diagnostic command "diagnostic bootup level complete" is not matching list of commands allowed on the switch as shown below:
#diagnostic ?
  mode      Configure Online Diagnostic Mode Information
  ondemand  On demand diagnostic setting
  start     Starting on demand diagnostic
  stop      Stopping diagnostic
what should I do?
You should try hard reseat of the sup card if still shows the same behaviour repalce the SUP.
1175
