Make SSO "hot" Supe720 "active" by command
What is the cleanest way to force a failover? Is there a command that can do this w/o reloading the active supe? We want the supe in the 1st slot to be the "active" one again.
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: Make SSO "hot" Supe720 "active" by command
They will switchover in SSO mode. I've done it plenty of times.
The command 'redundancy force-switchover' should accomplish your request
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/cmdref/r1.htm#wp1056699
Many thanks.
The docs say that the modules will not reload if it is running in RPR mode. I wonder if that is also true for SSO mode.
Thanks again it was a clean switchover. I didn't drop a ping. This command does cause the original "active" to reboot and there are messages about interfaces going down and up, but the servers never saw a disconnect.
118
