06-20-2009 04:58 PM - edited 03-06-2019 06:21 AM
In our network we are using CAT6500 as our core switch and 2950 and 3500 swithes as the access swithes
intially we run an trunk port betwenn all access switches and allowing some VLAN and created an interfacec VLAN in corresponding switch and we managed remotely
now due to some requirement we changed all trunk port to the access port allowing single VLAN per switch
problem is we are not able to take the switch remotely
for example :
CAT 6500:
interface GigabitEthernet12/31
switchport mode access
switchport access vlan 800
2950 :
interface range fastEthernet 0/10
interface vlan 800
ip address 10.190.10.5 255.255.255.0
we are not able to reach interface vlan IP in 2950 and 3500 swithes
and also in one 2950 switches its working but giving lot of input errors
can u please suggest us what is issue in this
is it possible to use managable ip with the access port
06-20-2009 09:57 PM
Vinoth,
To get rid of CDP errors. It would be look like this.
2950 :
interface vlan 800
To manage SwL2 remotely. Please add this command on Sw2960
ip default-gateway
HTH,
Toshi
06-20-2009 10:34 PM
hope that the interface fastEthernet 0/10 is uplinked to GigabitEthernet12/31 of 6500 series.
since trunk removal is the objectiveYou need to have
1) Per VLAN IP address for the purpose of Management in 6500 (for eg: VLAN 800 should have Management series IP for administring devices comes under VLAN 800)
2) in access switches the interface is not tagged under VLAN 800 (the UPLINK port) that has to be corrected.
06-26-2009 11:02 PM
thanks for your reply
I have done the same
CAT 6500:
2950 :
interface vlan 800
but what i see is that i am getting some errors on the interface can u advice me on this
Vlan800 is up, line protocol is up
Hardware is CPU Interface, address is 0009.43d9.fd40 (bia 0009.43d9.fd40)
Internet address is 10.79.10.5/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 128/255, txload 1/255, rxload 1/255
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 2w3d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3000 bits/sec, 59 packets/sec
5 minute output rate 6000 bits/sec, 4 packets/sec
101371713 packets input, 533460461 bytes, 0 no buffer
Received 5233518 broadcasts (0 IP multicast)
0 runts, 0 giants, 433271 throttles
93493725 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
6472772 packets output, 1509566855 bytes, 0 underruns
0 output errors, 0 interface resets
