Management domain length in VTP
I'm preparing for my CCNA. Please don't mind if this is too small question to ask here.
What does the Management Domain length contains in a VTP packet?
Here is the screenshot from a cisco doc for understanding VTP.
Chandu
Regards, Chandu
Everyone's tags (1)
1 ACCEPTED SOLUTION
Chandu,
1. Can we find out how many switches are there in the vtp domain including server, client & tansp?
There is no automatic tool for this. VTP protocol itself has no provisions to enumerate the count of switches in a VTP domain and their roles.
2. How to find the count of client switches & transp switches?
Not possible with VTP tools. You could of course visit the configuration of each switch and check its VTP settings but this option is probably not what you are asking for.
And finally is there any use to include the length of the domain name?
Because the IOS needs to know how many bytes in the "Management domain name" field are significant. If you were writing a software to process VTP packets, you would be able to read the entire "Management domain name" field as a 32-byte long string into memory easily, but you still need to know how long is the VTP domain name in that string.
Best regards,
Peter
Hi Chandu,
The "Management domain length" is an unfortunate field designation. In reality, this field says what is the length of the VTP domain name.
In VTP packet header, the field for VTP domain name - the "Management domain name" has a constant length of 32 bytes. However, the true length of the VTP domain name can be anywhere between 1 and 32 characters, so the packet also carries information about how long the name is, exactly in the "Management domain length" field. If your VTP domain name is, say, "CCNA" then only 4 bytes out of 32 are occupied in the domain name field, and the "Management domain length" would carry the value of 4.
Best regards,
Peter
VIP Purple
HI Chandu,
Management domain Length: Used to specify the length of the VTP management domain or Indicates the size of the name that follows
The main purpose of VTP is to provide a facility by which individual Cisco switches can be managed as a group for VLAN configuration purposes. A VTP management domain is simply a group of switches that participate in sharing VTP information. A given switch can be part of only one VTP management domain at a time, and is part of no VTP management domain by default.
Dont forget to rate helpful posts.
Thanks to you both.
I've two more questions:
Is there any way?
Thanks in advance.
Chandu
Regards, Chandu
Chnadu
Regards, Chandu
Chandu,
Best regards,
Peter
211
