Management Interface on a Aironet AP
Sub-intreface configuration on AP:
interface GigabitEthernet0.167
encapsulation dot1Q 167
ip addr 10.10.6.204 255.255.255.192
vlan configuration on switch:
interface Vlan167
ip address 10.10.6.201 255.255.255.192
interface configuration on switch:
interface GigabitEthernet0/16
description to ap1
switchport mode trunk
The show ip route x.x.x.x command on both devices list the preffered route as known via "connected".
Why would I be unable to ping the switch from the ap and the ap from the switch?  I have multiple SSID's / BVI's, / VLAN's configured on this AP with no issues.  I need tGigabitEthernet0.167 configured for management only.  Not tied to a BVI, SSID, etc.
Green
From the switch can you try:-
ping ip 10.10.6.204 sou vlan 167
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
switch#ping 10.10.6.204 source vlan 167
Sending 5, 100-byte ICMP Echos to 10.10.6.204, timeout is 2 seconds:
Packet sent with a source address of 10.10.6.201
Success rate is 0 percent (0/5)
switch#sh ip route 10.10.6.204
Routing entry for 10.10.6.192/26
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Redistributing via eigrp 1
  Routing Descriptor Blocks:
  * directly connected, via Vlan167
      Route metric is 0, traffic share count is 1
description to ap1
switchport trunk native vlan 167
Jawad
Jawad
Hall of Fame Super Gold
Re: Management Interface on a Aironet AP
Something is missing with your AP configuration.  Where's the NATIVE VLAN subinterface?
210
