Webcast-Catalyst9k
Management VLAN and Native VLAN
HI ALL,
Can u define The management VLAN and Native VLAN as per experience?
Hall of Fame Super Blue
Re: Management VLAN and Native VLAN
The management vlan is use to manage the switches themselves and as such should not have any user ports in them. Cisco recommends using a vlan other than vlan 1 for management ( we use vlan 2 in our sites ). Layer 2 switches can only have vlan interface up so this would be the management vlan with the default-gateway pointing to the Layer 3 SVI ip address for that vlan.
The native vlan is the vlan that is not tagged with a vlan ID when traversing a 802.1q trunk link. Again Cisco recommend using a deidcated vlan for this. Thre should be no user ports in it and you do not need a layer 3 SVI for this vlan as it does not need to be routable. We use vlan 999 at our sites.
Jon
Silver
Hi ,
If u have time ,Check the below link for good explanation.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a008013159f.shtml
Cheers :)
satish
297
