Community Member
Management VLAN Security Level
Should the management VLAN security level on ASA be higher than all other connected segments for e.g. Application and backend database segments.
1 REPLY
Bronze
Re: Management VLAN Security Level
Regarding the use of the management interface, you can use it as a regular interface. You have to issue the command 'no management-only' then configure the interface as if it was an ordinary interface. For further information click this link.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/int5505.html#wp1054877
266
