Managemnt Vlan Unable to ping
haikalmesiniaga
Hi All,
MY MGMT Vlan having some issues,sometimes can ping sometimes cannot.
interface GigabitEthernet0/1
switchport access vlan 100
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan100
description MANAGEMENT
ip address  X.X.X.X 255.255.255.0
no ip route-cache
10 Replies 10
fb_webuser
Level 6
Level 6
Can you change the GigabitEthernet0/1 interface switch port mode to access and test it?
BR,
Libi
Posted by WebUser Libi Pappachen from Cisco Support Community App
Parvesh Paliwal
Level 3
Level 3
Are you connected directly to "GigabitEthernet0/1" ?
is there a connection drop or what ?
some specific errors or are there ping drops ??
switchport mode trunk  ------ change this one to swithcport mode access
and what equipment is connected in G0/1?
PC or Layer2 devices?
Another switch (3560) is connected to Gig port.all switch able to ping each other.Only this switch,sometimes can ping,sometimes cant from my side.Switch to switch can ping.
Is it releated with hardware error ?Gbic module perharps ?
Nope.Its connected to next switch.Now cant ping/telnet...after sometimes,can ping and connected to the device..others switch is ok...
Dear haikal,
If another Switch is connected to Gig 0/1 . Plz confirm that its also configured in trunk mode. If you are not able to configure another port as trunk then configure this command in Gig 0/1.
switchport nonegotiate
I hope it will help you.
pls check 'ip routing' enable to disable for this
Br/Subhojit
Hi All,
thanks for your help....I believe the problem is someting related with VTP.
Checked on VTP status
sh vtp counters
VTP statistics:
Summary advertisements received    : 151079
Subset advertisements received     : 8
Request advertisements received    : 4229
Summary advertisements transmitted : 172039
Subset advertisements transmitted  : 4231
Request advertisements transmitted : 26
Number of config revision errors   : 0
Number of config digest errors     : 20958
Number of V1 summary errors        : 0
VTP pruning statistics:
Trunk            Join Transmitted Join Received    Summary advts received from
                                                   non-pruning-capable device
Gi0/1               0                0                0
Gi0/2               0                0                0
sh vtp status
VTP Version capable             : 1 to 3
VTP version running             : 1
VTP Domain Name                 : autos
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Disabled
Device ID                       : 9c4e.2030.xxxx
Configuration last modified by 10.112.117.199 at 3-1-93 01:09:03
Feature VLAN:
VTP Operating Mode                : Client
Maximum VLANs supported locally   : 255
Number of existing VLANs          : 12
Configuration Revision            : 0
MD5 digest                        : 0xAE 0x35 0xF9 0x35 0x31 0x05 0x9F 0x0D
                                    0x4E 0x94 0x47 0xB7 0xCB 0xB3 0xA9 0x9A
*** MD5 digest checksum mismatch on trunk: Gi0/1 ***
*** MD5 digest checksum mismatch on trunk: Gi0/2 ***
Some of the switch running VTP Version2,while this switch is running version 1.
Will try to change the VTP version to Version 2.
FYI , the switch can ping after i console..no changes made to configuration ...
haikalmesiniaga
Hi,how to fix this error ?
