09-19-2017 11:17 AM - edited 03-08-2019 12:05 PM
hi Team,
i have 7200 chassi in that where Gi6/0 interface is genarating High input errors.
show int gi6/0 | i error
2353591 input error,4695overrun,2348896 ignored
kindly suggest on the above.
09-19-2017 11:40 AM
Have you replaced the cable?
09-19-2017 01:58 PM
hi Reza,
yes i have done the same but still inputerroe is increasing
GigabitEthernet6/0 is up, line protocol is up
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 4/255
30 second input rate 16730000 bits/sec, 4477 packets/sec
30 second output rate 6731000 bits/sec, 2702 packets/sec
1038762980 packets input, 628305209 bytes, 0 no buffer
Total output drops: 1053
2361301 input errors, 0 CRC, 0 frame, 4695 overrun, 2356606 ignored
Please check on the above.
09-19-2017 02:14 PM
How is the CPU performing in the last 72h?
Post the output of the following
Show run int gi6/0
Show int gi6/0
Show ip in gi6/0
Is there a policy-map applied to the control-plane?
09-19-2017 02:35 PM
interface GigabitEthernet6/0
description *** PRI_IOR-CC1-Port NO ****
ip address <ip address>
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip pim sparse-mode
ip igmp static-group 239.1.1.1
ip cgmp
ip ospf network broadcast
ip ospf 100 area <area no>
ip ospf cost 20
load-interval 30
negotiation auto
no cdp enable
service-policy input Wipro-MPLS-QOS
service-policy output Wipro-MPLS-QOS-IN
hold-queue 8192 in
Hardware is WISEMAN, address is 0015.f9a9.45a8 (bia 0015.f9a9.45a8)
Description: *** PRI_IOR-CC1-Port NO ****
Internet address is <Ip address >
Keepalive set (10 sec)
Full Duplex, 1000Mbps, link type is auto, media type is SX
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d11h
Input queue: 0/8192/0/0 (size/max/drops/flushes); Total output drops: 1053
Queueing strategy: fifo
Output queue: 0/40 (size/max)
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 690257 multicast, 0 pause input
880716277 packets output, 2904384099 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 66346 pause output
Is there a policy-map applied to the control-plane?No
i can observe cpu was high at peak hrs
%SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Utilization(Total/Intr): 80%/75%, Top 3 processes(Pid/Util): 5/3%, 267/0%, 50/0%
09-19-2017 02:52 PM
09-19-2017 03:14 PM - edited 09-19-2017 03:23 PM
09-19-2017 03:20 PM - edited 09-19-2017 03:24 PM
09-19-2017 03:21 PM
Hi Leo,
thanks for the response.
so as a first level trouble shoot what we can perform apart from cable change?
what is "66346 pause output" error?
is overrun is related to " capability of the interface , if it execeeding the solution is only rate that frames are coming should be controlled at the remote end of the connection. Otherwise, if the number of overruns is high, the hardware should be upgraded. "?
is it related to traffic?
Please clarify the above...
09-19-2017 03:24 PM
09-19-2017 03:58 PM
Hi leo,
I will check the recomented things and will keep you posted by tomorrow EOD.
09-21-2017 06:04 PM
Hi leo,
i have changed the cable and checked the SFP but still errors are occuring .also in show log am able to see the CPU high alam some time.Please help and let me know how can i proceed further to resolve this issue.
09-22-2017 12:31 AM
09-20-2017 06:14 AM
09-20-2017 12:34 PM
Hi Joseph,
NPE-G1 is using in the device.
Cisco 7206VXR is the exact model .
and module 6 part "PA-1GE= " where we are getting the input error.
So you are pointing as the CPU is also cause for this issue?
As in logs i can observe the cpu utilization was high at lot of times it was arround 82%/78%,
Please clarify ..?
