08-25-2014 11:45 PM - edited 03-07-2019 08:31 PM
Dear Team,
If I am marking my traffic with L2 QOS and sending the marked traffic over the WAN (MPLS Cloud) to the destination, Am I going to get the effect of the marked QOS over the WAN till it reaches the destination.
by the same way if I am enabling the QOS for the traffic from my location WAN router, does this QOS effect exist till it reaches the destination over the WAN.
Jubair.S
Solved! Go to Solution.
08-26-2014 07:27 AM
You can not be sure what the MPLS carrier company/network
does with its LAYER 2.
You would be far safer to mark your traffic at LAYER3 (DSCP or IP -PREC)
before sending it on to the MPLS.
Alex
08-26-2014 07:27 AM
Alex
08-26-2014 10:00 PM
Hi Alex,
Thanks for the answer, however I need to mark the traffic from the access switch where my server is connected. May I use COS to DSCP mapping and send to over the WAN network till the destination. Will this work???
Jubair.S
