Webcast-Catalyst9k
Match Incoming traffic from Nexus 2248
I am trying to create a service policy on a Nexus switch to match a certain class of traffic and I am having problems.
I have a server connected to a 2248 which is connected by port channel 10 to the 5548. and I want to create an access list that would classify the traffic from the host and put it into the correct cos-group. For what ever reason I cannot get it to work
Here is what I have
ip access-list SERVER_QOS
10 permit ip 172.16.10..0/24 any log
set dscp af11
class-map type qos match-any SERVER_QOS
match access-group name SERVER_QOS
class-map type queuing SERVER_QOS
match qos-group 4
policy-map type qos SERVER_QOS
class type qos SERVER_QOS
set qos-group 4
policy-map type queuing SERVER_QOS
class type queuing SERVER_QOS
bandwidth percent 50
Since this is a FEX I put the policy on the port-channel
interface port-channel 10
service-polity type qos input SERVER_QOS
service-policy type queuing input SERVER_QOS
service-policy type queuing output SERVER_QOS
When I do a show policy-map interface port-channel 10 I see the service policy applied
I never see any hits on the access-list or anything goes into cos-group 4. Everything seems to go in to the default class
Any ideas what I am missing
Everyone's tags (1)
1 REPLY
Hi,As far as I know, QoS
As far as I know, QoS policy under FEX link is not supported.
You may apply the policy to system qos.
HTH.
Jay Ocampo
66
