07-22-2010 05:57 PM - edited 03-06-2019 12:09 PM
Does anyone know what is the maximum number of static routes that can be placed on a Cisco 2501 router? It is currently running 11.1(4) releasce (fc)
Ball park figure accepted.
Albert
07-22-2010 06:50 PM
Hi Alber,
The maximum memory an the 2500 series is only 16Mb, so you really should not have that many routes on the routing table. If I ware to guess, it would be the range of 500 to 1000 static routes.
Reza
07-23-2010 01:26 AM
Albert
Hi Albert,
Main Processor Memory is used for routing tables, fast switching cache, running configuration, and so on. It can take unused shared I/O memory, if needed.
Check out the below link for more information for 2500 series routers
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a0080094e93.shtml
Hope to help !!
Ganesh.H
