03-18-2010 08:26 AM - edited 03-06-2019 10:12 AM
Hello Everybody ,
I've received from our management station the following message : Memory excessive fragmentation, Someone could you say me if they are some commands for throubleshoot this error and see the memory status of the switch.
The running platform is : WS-C6509 with WS-X6K-SUP2-2GE supervisor.
thanks in advance
gianfranco
03-18-2010 09:38 AM
Hello Gianfranco,
you should use
sh proc mem
example
sh proc mem
Processor Pool Total: 168488064 Used: 69705432 Free: 98782632
I/O Pool Total: 35651584 Used: 9616800 Free: 26034784
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 72180632 8760800 58147560 0 0 *Init*
0 0 15824 175449416 15824 0 0 *Sched*
0 0 1824137536 1763277992 690112 8978216 0 *Dead*
taken from a device like yours
Hope to help
Giuseppe
03-19-2010 01:59 AM
thanks for your message
03-18-2010 09:59 AM
Gianfranco:
You have to investigate why the memory allocation is fragemented in the first place. It could be a result of a DoS attack on the control plane, which is pretty easily addressed with CoPP.
Or you can be using a dated version of IOS. An upgrade may be in order.
Sometimes something as simple as a reboot clears the memory buffers and clears the problem....
Victor
