10-28-2013 01:00 PM - edited 03-07-2019 04:17 PM
I'm having some sporadic network issues (users sporadically losing network connectivity). I'm wondering if the problem is related to Mac flapping that has been occuring. Every floor's access switch (Catalyst 2960s) is connected to the core switches (Nexus 5K) via a vpc connection. I see several Mac flapping notifications throughout the day and I believe it is because my clients are roaming between access points. There is quite a lot of bleed over between floors and clients will roam between APs pretty easily. Here is a log from one of the access switches:
Log Buffer (4096 bytes):
8.624: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0012 in vlan 18 is flapping between port Gi1/0/23 and port Po1
023020: Oct 28 15:26:58.624: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0018 in vlan 24 is flapping between port Gi1/0/23 and port Po1
023021: Oct 28 15:26:58.624: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001b in vlan 27 is flapping between port Gi1/0/23 and port Po1
023022: Oct 28 15:26:58.624: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001d in vlan 29 is flapping between port Gi1/0/23 and port Po1
023023: Oct 28 15:26:58.624: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001e in vlan 30 is flapping between port Gi1/0/23 and port Po1
023024: Oct 28 15:26:58.624: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0021 in vlan 33 is flapping between port Gi1/0/23 and port Po1
023025: Oct 28 15:26:58.634: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0001 in vlan 1 is flapping between port Gi1/0/23 and port Po1
023026: Oct 28 15:26:58.634: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0002 in vlan 2 is flapping between port Gi1/0/23 and port Po1
023027: Oct 28 15:26:58.634: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0016 in vlan 22 is flapping between port Gi1/0/23 and port Po1
023028: Oct 28 15:26:58.634: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0019 in vlan 25 is flapping between port Gi1/0/23 and port Po1
023029: Oct 28 15:26:59.116: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001a in vlan 26 is flapping between port Gi1/0/23 and port Po1
023030: Oct 28 15:26:59.116: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001c in vlan 28 is flapping between port Gi1/0/23 and port Po1
023031: Oct 28 15:26:59.116: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001f in vlan 31 is flapping between port Gi1/0/23 and port Po1
023032: Oct 28 15:26:59.116: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0020 in vlan 32 is flapping between port Gi1/0/23 and port Po1
023033: Oct 28 15:26:59.116: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0029 in vlan 41 is flapping between port Gi1/0/23 and port Po1
023034: Oct 28 15:38:00.836: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0001 in vlan 1 is flapping between port Gi1/0/21 and port Po1
023035: Oct 28 15:38:00.836: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0002 in vlan 2 is flapping between port Gi1/0/21 and port Po1
023036: Oct 28 15:38:00.836: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0016 in vlan 22 is flapping between port Gi1/0/21 and port Po1
023037: Oct 28 15:38:00.836: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0019 in vlan 25 is flapping between port Gi1/0/21 and port Po1
023038: Oct 28 15:38:00.836: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001a in vlan 26 is flapping between port Gi1/0/21 and port Po1
023039: Oct 28 15:38:00.836: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001c in vlan 28 is flapping between port Gi1/0/21 and port Po1
023040: Oct 28 15:38:00.836: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001f in vlan 31 is flapping between port Gi1/0/21 and port Po1
023041: Oct 28 15:38:00.841: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0020 in vlan 32 is flapping between port Gi1/0/21 and port Po1
023042: Oct 28 15:38:00.841: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0029 in vlan 41 is flapping between port Gi1/0/21 and port Po1
023043: Oct 28 15:38:00.841: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0000 in vlan 23 is flapping between port Gi1/0/21 and port Po1
023044: Oct 28 15:38:00.841: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0012 in vlan 18 is flapping between port Gi1/0/21 and port Po1
023045: Oct 28 15:38:00.847: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0018 in vlan 24 is flapping between port Gi1/0/21 and port Po1
023046: Oct 28 15:38:00.888: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001b in vlan 27 is flapping between port Gi1/0/21 and port Po1
023047: Oct 28 15:38:00.888: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001d in vlan 29 is flapping between port Gi1/0/21 and port Po1
023048: Oct 28 15:38:00.888: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.001e in vlan 30 is flapping between port Gi1/0/21 and port Po1
023049: Oct 28 15:38:00.894: %SW_MATM-4-MACFLAP_NOTIF: Host 0281.3c5d.0021 in vlan 33 is flapping between port Gi1/0/21 and port Po1
Here is the config of both interfaces:
IDF10#sh run int g1/0/21
Building configuration...
Current configuration : 95 bytes
interface GigabitEthernet1/0/21
switchport trunk native vlan 23
switchport mode trunk
end
IDF10#sh run int g1/0/23
interface GigabitEthernet1/0/23
end
10-28-2013 05:04 PM
Your issue has got NOTHING to do with wireless. Error messages like this is commonly attributed to your uplink ports not properly configured for Etherchannel and your port configurations proves it.
10-29-2013 03:34 AM
How should the ports be configured? The APs themselves are on VLAN 23. The users are placed in a different VLAN based on the SSID that they connect to. Is there a document that I can review that references this?
10-29-2013 03:59 AM
Presumably Gi1/0/21 and Gi1/0/23 should be part of Port Channel 1?
What is connected to Gi1/0/21 and 23? Access points?
10-29-2013 04:14 AM
Port Channel 1 is made up of two spf+ and is a vpc to the core switch. The Catalyst 2960s that is connected to po 1 has Meraki MR16s connected to Gi1/0/21 and 23. I don't understand why I would want to connect these to po 1.
interface Port-channel1
description Port-channel to Core
load-interval 30
interface TenGigabitEthernet1/0/1
channel-group 1 mode active
interface TenGigabitEthernet3/0/1
end
10-29-2013 04:20 AM
Post the output to the command "sh etherchann 1 summary".
10-29-2013 04:30 AM
RE: "I don't understand why I would want to connect these to po 1." I don't understand either why?
Also i;ve seen the same messages at different customer sites with differet hardware that I can confirm are relaed to roaming wi-fi clients.........so I don't agree with Leo's comments either at this stage.
10-29-2013 04:40 AM
Sounds to me like clients are roaming between access points which are physically connected to different access switches.
I am guessing these are autonomous access points and not controller based?
It could be normal in a wireless network where clients regularly roam.
10-29-2013 04:46 AM
"It could be normal in a wireless network where clients regularly roam" Based on experience I tend to agree.
10-29-2013 08:12 AM
IDF10#sh etherchann 1 summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 6
Number of aggregators: 6
Group Port-channel Protocol Ports
1 Po1(SU) LACP Te1/0/1(P) Te3/0/1(P) Te4/0/1(D
10-29-2013 05:48 PM
Draw your network.
