01-23-2012 06:15 AM - edited 03-07-2019 04:30 AM
Hello
Could you please someone explain me purpose of Message age timer , As I uderstand it , from ROOT bridge to other decrease MAX age value , respectively increase Message age from 0 to 19 , with diameter 7 , but why >?
Thanks in Advance
Solved! Go to Solution.
01-23-2012 07:41 AM
Hi Roman,
The Message Age field in STP is similar to a TTL field in IP packet and is supposed to
The Message Age is set to 0 at the root bridge. Every other non-root switch will increase the Message Age field by one in the received BPDU when relaying it via its own ports. Moreover, on each non-root switch, the BPDU itself will age out in (Max Age - Message Age). This makes sure that the more hops this BPDU has traversed from the root, the sooner it will expire.
This document also may be interesting for you:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a0080094954.shtml
Of course, feel welcome to ask further!
Best regards,
Peter
01-23-2012 07:41 AM
Hi Roman,
Best regards,
Peter
01-23-2012 08:19 AM
Oh , thanks ,so that means , if diameter is 7 and I manualy set up maximu age to for example to 25 , last switch in topology could not recieve BPDU ? ...
01-23-2012 09:46 AM
Hello Roman,
I am not sure how you arrived to that conclusion - but it is incorrect. Assuming that the root switch is at one end of the 7-switch chain, the very last switch at the other end will receive the BPDUs with whatever Max Age you configured, and with the Message Age of 5. This BPDU will therefore expire in (Max Age - 5) seconds. Unless you configure your Max Age to 7 or less, the BPDU will be accepted and processed. If the Max Age was 7, the BPDU would expire in 7-5=2 seconds which is exactly the Hello time - hence the BPDU would expire at approximately the same time as it is expected to be received, and this could lead to very unpleasant results.
Having the diameter of 7 and the Max Age set to 25 will not produce any ill results - at worst, the BPDU will expire in 25-7=18 seconds at the farthest switch.
Best regards,
Peter
01-23-2012 10:38 AM
Ok
Sorry , I meant it right , but I have used wrong values ...
Thank you ...
Roman
08-24-2016 12:52 PM
Hi Peter
it is totally clear for me how Message Age field works and how each Non-root Switches uses and increment the value, my question now is, why does STP need the farther switches expiries its BPDUs stored sooner?
As an example, if I have 5 switches chained and the first one is the root if something happens to it the first that start announcing as new root-bridge is the last one on the opposite direction, why does the protocol do that?
Thanks a lot
