metric values in BGP
R1#sh ip bgp 170.190.140.0 255.255.255.0
BGP routing table entry for 170.190.140.0/24, version 1324996
Paths: (2 available, best #2, table Default-IP-Routing-Table)
Multipath: eBGP
Not advertised to any peer
64806 64872 64852 64851 64871 64811 65531 64812
10.16.70.122 (metric 6) from 10.16.70.122 (10.23.127.8)
Origin IGP, metric 0, localpref 100, valid, internal
There're 2 metric values (0 & 6) in the above BGP statement..Can someone please tell me what do they pertain to?
Thanks...
Re: metric values in BGP
- IGP (OSPF, ISIS, RIP....) metric
- BGP metric, or MED value (default is 0)
Thanks for your response...
Multipath: eBGP
10.16.60.14 (metric 6) from 10.123.127.7 (10.23.127.7)
Origin IGP, metric 0, localpref 100, valid, internal, best
So, if the BGP metrics are identical between the 2 routes above, why is the second route the best one? Thnx again...
axfalk,
Can you posted the output of "show ip bgp summary"? It is possible that 10.123.127.7 established the BGP session with your router first (#10). If the up time for both peers are the same. Then it is choosing the lower's BGP router ID - 10.123.127.7 (#11).
Please check out the link which explain the BGP Best Path Selection Algorithm.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
HTH,
jerry
in your example all BGP attributes for both pathes are identical it means that 2 last tiebreakers decide which path will be the best, they are the smalles router-id and the smallest neighbor id.
in your case the router with router-id 10.23.127.7 was choosed.
721
