Metroethernet QoS..
Hi all,
We are using Metro Ethernet between HQ and Branch. On HQ, there is a 4506 and on Branch, there is a 4506. and the physical speed is 1Gbps each other but Service Provider is limeted to 10Mbps.
What I want to do are ..
1. Limit the HTTP Traffic to 3Mbps
2. Guarantee the EIGRP Traffic to 1Mbps.
3. Other Traffic are changed fair queue
4. Other traffic are RED.
Configuration is ...(On HQ side..)
ip access-list extended EIGRP
permit eigrp any any
ip access-list extended WWW
permit tcp any any eq www
class-map EIGRP_CLASS
match access-group name EIGRP
class-map WWW_CLASS
match access-group name WWW
policy-map POL_EIGRP_HTTP
class EIGRP_CLASS
bandwidth percent 10
class WWW_CLASS
police 3000000 300000 conform-action
transmit exceed-action drop
class class-default
fair-queue
random-detect
int gig 1/1
service-policy output POL_EIGRP_HTTP
bandwidth 10000
end
Is that work out ?
Someone thinks I was wrong.
Normaly When we use a Metro Ethernet, ISP limit the bandwidth based on the contract.
In this case We contracted 10Mbps but the Physical bandwidth is 1Gbps and then If I configure the QoS like above, this will not work out, because ISP is not interest in our traffic priority, they are only interest in bandwidth even though QoS Configuration. So When we send more than 10Mbps, They will discard some packet including the EIGRP & HTTP.
So Resolution is We should send less than 10Mbps to guarantee EIGRP & HTTP traffic.
Is that right ?
Another question is
If I configure the bandwidth of an interface gig 1/1 from 1Gbps to 10Mbps, Is the traffic is limited to 10Mbps ?
142
