Webcast-Catalyst9k
MIB variables for cat3560 switch
We have cat3560 switches. I have setup switches for threshold alerts in LMS 3.1, but some switches show more variables than others. How can I check variables on a switch so that it can be compared with other switches?
1 REPLY
Silver
Re: MIB variables for cat3560 switch
While configuring Specify the absolute keyword to test each MIB variable directly. Specify the delta keyword to test the change between samples of a MIB variable
View your running config to verify the entries.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.1_19_ea1/configuration/guide/swrmon.html
121
