Migration from WS-C3560 to WS-C2960X
Maurycy
Im planning a migration from this switch:
https://www.amazon.com/Cisco-WS-C3560-24TS-S-Catalyst-3560-24TS-Switch/dp/B0007VOF0I
to somthing newer, like this:
https://www.cisco.com/c/en/us/support/switches/catalyst-2960x-24ts-l-switch/model.html
My question is, according to various research i'm doing currently, can I upload configuration from older to newer?
best regards,
Maurycy
Hi Maurycy,
Yes, you can upload the configuration from older to newer switch.
But you have to take care of few things, like boot system command should not be there in old config.
It will be good if you will do copy and paste the configuration from old switch configuration to new switch, in this way you can remove the things which are not required for the new switch.
Spooster IT Services Team
Hi Maurycy,
Thank you!
Thank you for the rating.
