01-29-2008 10:36 AM - edited 03-05-2019 08:47 PM
I am replacing a 2600 switch with 3750 in my network , could some one suggest me the basic checks that need to consider apart from the configuration..
Tnx.
01-30-2008 07:59 AM
Do check up for the features available on each ios image (2900 and 3750).
And i hope you are mentioning 2600 series switch here in place of 2900 series switch.
regds
01-30-2008 08:49 AM
Not really, I am replacing the 2600 XM Series with 3750.Thanks for the reponse.Anyother checks reqired..?
01-30-2008 11:07 AM
If your 2600 is running advanced routing protocols you need to ensure your 3750 has emi ios. If you 2600 has any serial interfaces, you'll find those are not supported with 3750s. I dont think 3750s support bgp. 3750s do not support VoIP configurations a'la voice cards etc. post your config from your 2600 and we can see if it is compatible with a 3750.
01-30-2008 11:34 AM
01-31-2008 12:30 AM
According to the Software Advisor (http://tools.cisco.com/Support/Fusion/FusionHome.do) this version does support BGP.
