Community Member
Missing NAT Pool
Hi all. I have a mysterious case with a NAT pool configured over 2 C2600 (ver 12.2 and ver 12.3) with HSRP. One active, and the other in standby mode.
Both routers have 2 nat pools in use. I can see both working with "sh ip nat statistics".
The problem is that I cannot see one of the nat pool in the running-config nor startup-config.
I know it's there because i see the statistics and in fact it is working but it is not usual.
The nat pool missed looks like:
ip nat pool my-pool 172.17.32.100 172.17.32.199 netmask 255.255.255.0
The nat pool that does appear in the configs looks like:
ip nat pool my-other-pool prefix-length 25
address 172.18.55.34 172.18.55.43
The line that associates the missed pool with its access list appears in the configs without problem, its just the pool line.
It happens in both routers.
Thanx!
1 REPLY
Re: Missing NAT Pool
Can you post the whole config of your router here ?
regds
225
