07-18-2012 08:27 AM - edited 03-07-2019 07:50 AM
Dear all
Any one try to form a stack with mixed 3750-X and 3750G? Is there any prerequisites in hardware and software?
Best regards
Alex Tsang
07-18-2012 09:22 AM
yes we have done it.
the software version needs to be the same.
for instance all switches have 12.2(58)SE2.
only the G switch has ipbase and X switch has universal image.
I don't know about other pre-requisitives but maybe other peeps can say something about that.
07-18-2012 04:03 PM
What are the flash capacity of all the 3750G in the stack?
If it's 16 Mb flash, then the highest IOS you can load on a 3750G with 16 Mb flash is 12.2(55)SE and later (SE, SE1, SE2, SE3, SE4 and SE5).
You CANNOT and WILL NOT be able to load 12.2(58)SE and 15.0(1)SE on a 3750G with 16 Mb flash.
07-19-2012 01:08 AM
we have the 64MB version, so no problem there!
07-19-2012 03:36 PM
Hmmm ... I've never seen a plain 3750/3750G with 64 Mb flash. Must've be a new model.
07-23-2012 06:21 PM
Have stacked 3750X and 3750V1 using 122-55.SE3 with no issues.
03-24-2014 12:56 PM
Interesting. Have you used all the same image or different images for 3750G and 3750X but with the same revision#?
03-24-2014 02:50 PM
It won't make any difference what "revision" number the hardware is. The main rule still applies: Each member of the stack must have the same IOS version and same feature set.
03-24-2014 01:27 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Just wanted to mention when you mix original StackWise with StackWisePlus, StackWisePlus falls back to StackWise mode. I.e. you lose some of the "Plus" features.
