Mixing Copper & Fiber ports in an Etherchannel
anjery1234
Wondering whether it is possible to have copper and fiber as part of the same port-channel group?
PO1
RP01                           RP02
int 1: fiber--------------------int 1: fiber
int 2: fiber--------------------int 2: fiber
int 3: copper----------------int 3: copper
int 4: copper----------------int 4: copper
7 Replies 7
Reza Sharifi
Yes, you can mix copper and fiber ports together, as long as they are all in the same speed and duplex.
Reza
Reza,
Thanks for the quick reaction.
Do you have a link that I can use in my presentation to support that?
Leo,
I guess as long as my copper ports are gig, I should be fine!!!
Yes, it is fine. Copper of fiber same speed works fine.
Leo Laohoo
They need to be of the same color too.
EtherChannel technology is not dependent on any  type of media—it can be used with Ethernet running on existing  unshielded twisted pair (UTP) wiring, or single-mode and multimode  fiber.
the logical duplex and seep is to be identical in the channel.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_white_paper09186a0080092944.shtml#wp39673
https://learningnetwork.cisco.com/message/70930
Thinakaraj.M
