mls qos command
If switches do not have the mls qos command what happens to incoming packets that have a DSCP or CoS value configured?  Do they get reset?
Also, if a switch does have mls qos command, but an interface is not set to trust DSCP or CoS, will any marking get reset?
thanks
Hall of Fame Super Blue
Re: mls qos command
Luca
Because QOS is quite different between Catalyst platforms the best thing to do is look at the default configuration for each switch to answer your question eg.
3560 -
3560 default configuration
6500 -
6500 default configuration
For others you can get to the configuration docs from the cisco homepage -> Products & Services -> Switches -> switch you are interested in and then select the configuration docs.
Jon
Re: mls qos command
Thanks i'll have a read.... This questions is relevent to 3560 switches.
Re: mls qos command
to enable qos on a switch u must enter mls qos
if the it is cos trust it will remark it will take the trusted value
997
