Community Member
MLS VTP-Domain Issue
Greetings,
I am attempting to configure a router interface as the mls management interface.
Router(config)# mls rp ip
Router(config)# interface gi0/0
Router(config-if)# mls rp vtp-domain blah
Router(config-if)# mls rp vlan-id 107
Router(config-if)# mls rp ip
Router(config-if)# mls rp management-interface
My issue is with the vtp-domain command. Whenever I enter it, I get a message saying "interface gigabitEthernet0/0 currently in -null- domain"
I was wondering if anybody could shed any light on the issue.
1 REPLY
Hall of Fame Super Silver
Re: MLS VTP-Domain Issue
Hello Brian,
may you check with sh mls on the L2 switch if the RP is accepted by the switch ?
on the Router try to use:
show mls rp vtp-domain blah
Usage Guidelines
The assigned IPX MLS interface must be either an Ethernet or Fast Ethernet interface-both without subinterfaces.
Examples
The following example shows how to assign the MLS interface to the VTP domain named engineering:
Router(config-if)# mls rp vtp-domain engineering
see
http://www.cisco.com/en/US/docs/ios/12_3/switch/command/reference/swi_m1.html#wp1033041
I wonder if you need it from your config it looks like you haven't subifs.
In first edition of CCNP switching says it is needed on the physical port on a trunk with VLAN subifs.
If you haven't a trunk port VTP info isn't exchanged with the switch.
I think that or you need mls rp vlan-id X or you use mls rp vtp-domain blah
the first is needed to inform the router its interface is in Vlan X for the switch and is used on a port without subifs connected to an access port on the switch.
the second is for a trunk port with Vlan subifs.
Or simply you need to provide the mls rp vtp-domain as the last command after mls rp ip.
I remember there was a trick about this.
Hope to help
Giuseppe
156
