Modem Dialup for 6509E console
Is it enabled by default?If not what is the command to enable it?
1 REPLY
Silver
Re: Modem Dialup for 6509E console
Catalyst 4500/4000, 5500/5000, and 6500/6000 switches that run CatOS have the optional command set system modem {enable | disable}. This command enables hardware flow control (use of Request to Send [RTS]/Clear to Send [CTS] signals) on the console port.Refer URL
http://www.cisco.com/en/US/partner/products/hw/switches/ps679/products_tech_note09186a0080094b30.shtml#setsysmodcom
233
