01-19-2007 08:29 AM - edited 03-05-2019 01:53 PM
I need to modify the startup-config file from a 6500 switch and then transfer it via ftp to another 6500 switch. I'm not sure what format I should use to save the file.I'm using notepad to edit the file. If I save the file with ANSI encoding, will the switch be able to read the file? If not,what is the best way to do this?
01-19-2007 08:41 AM
If you copy the config file via FTP to your workstation and edit the file in notepad, you can copy it to the new switch (via FTP) and the new switch should read it just fine. You could always copy-n-paste too, but that's a little slow.
HTH and please rate.
01-19-2007 10:36 AM
thanks for the response. but what format should i save the file in after editing in notepad?
01-19-2007 11:29 AM
It looks to me like ANSI would be the format to use. When I edit a config retreived by TFTP it appears to be using ANSI formatting.
Rick
01-19-2007 01:58 PM
I work/save in ANSI.
01-19-2007 09:30 PM
When u download the startup file it will save in .cfg extention then modify it and then resave with .cfg extention and upload it your problem will solve
