01-21-2012 04:17 PM - edited 03-07-2019 04:28 AM
I just wanted to clarify a few things.
When you have Switch A and Switch B connected together via a trunk. Let's this link is a 100mbps link, so it has a STP cost of 19,
and I want it to have a cost of 10 on Switch B. As far as I know, all you do is run a 'spanning-tree vlan 1 port cost 10' command for
instance on the port going from B to A. That way when A sends out its bpdu with a cost of 0, it hits Switch B's port and then adds
0+10 = 10 instead of 0+(19 default) = 19.
Also, is it correct that when you modify port priority, for instance I would need to modify the priority on the port from Switch A going to
Switch B?
Solved! Go to Solution.
01-22-2012 07:25 AM
Cost is done on the recv'g interface config.
Port priority is done on the opposite interface.
For a great video explaining, go to this link:
http://www.youtube.com/watch?v=8CZiVd2K9CI&feature=player_embedded
Its by Keith Barker, great video about both concepts.
Message was edited by: Jimmy Sands
01-22-2012 07:25 AM
01-22-2012 08:57 AM
Hi John,
STP uses some criteria to determine the (root port) , the root port in a designated bridge is a port that recieves the BPDU from the root bridge as well as sends TCN BPDUs towards the root.
STP choses the root port (RP) based on the following:
1- The Lowest port cost on the designated bridge is elected first.
2- If there is a tie, the Lowest port priority.
3- If there is a tie, the lowest port-id.
Now, lets consider we have the following example:
SWA (F0/0) ------------------------------------------ SWB (F0/0)
SWA (F0/1) ------------------------------------------ SWB (F0/1)
Now lets assume SWA is the root bridge for whatever Vlanx, SWB determines its root port based on the lowest cost of its ports F0/0 OR F0/1. if both ports have the Same Cost, then SWB choses the port with lowest port priority, if there is still a tie, SWB choses F0/0 as its root port since it has the Lowest Port-ID.
And yes, you are correct about your describtion.
Mohamed
01-22-2012 12:51 PM
Thanks for the claification.
