06-30-2013 10:45 AM - edited 03-07-2019 02:09 PM
I will be removing and adding several VLAN's from some cisco to cisco network infrastructure links.
IOS and NX-OS equipment
I would like to overwrite the existing "switchport trunk allowed vlan" config instead of using the vlan add or vlan remove commands. Is there any issues I may run into by overwriting? my small lab mockup showed no ping drops.
example:
current config "switchport trunk allowed vlan 10-20,25,30"
I would like to overwrite it with "switchport trunk allowed vlan 10,25,30-40"
I don't want to cause any impact to the users on the vlans that are not being removed (10,25,30)
06-30-2013 10:57 AM
The simple command replacement you cite will work fine and should indeed not impact current users' connections on VLANs 10, 25, and 30.
06-30-2013 11:13 AM
This is actually a very good question! Although I do not know the answer myself, I see you have a lab available so the test I would personally perform is debugging the STP to see if the VLANs 10, 25, and 30 are not renegotiated in STP after you modify the switchport trunk allowed vlan command. It is the STP that can cause transient connectivity outages.
Run the following debugs:
debug spanning-tree events
and then try to replace the existing switchport trunk allowed vlan command with the other. The debugs will show that the STP will be triggered for the VLANs that were newly added and possibly removed, but the debugs should not mention the VLANs 10, 25 or 30.
What kind of STP are you running, anyway?
Best regards,
Peter
06-30-2013 12:03 PM
Hi Peter,
I ran the following with debug spanning-tree events on the 4900m access switch
N7K<-->N5548<-->4900m<-->host
overwrote it with "switchport trunk allowed vlan 10,25,30-31"
pings to vlan10's SVI HSRP VIP(N7K) were good and the only STP events i saw on the 4900m was to the vlans removed and added.
ex.
remove event for vlan11 "RSTP(11): updt roles, root port te1/1 going down" etc
add event for vlan 31 "RSTP(31): initializing port te1/1" etc
I also ran debugs on the N5548 and saw no events until i made the same changes on its interface going to the 4900m.
which is expected as the port to the 4900m is desg
So no pings were lost and no stp events for the vlans not changing
I feel better about making the changes..thanks!
