Webcast-Catalyst9k
Module Compatibility between 6509 and 6509E
Hi There,
We are planning to upgrade the existing 6509 to 6509E.
Can I reuse the line cards WS-X6516-GBIC, WS-6516-GE-TX, and WS-X6548-RJ-45 from the existing 6509 to new 6509E chassis?
Thanks in advance.
Muru
Super Bronze
Re: Module Compatibility between 6509 and 6509E
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe almost anything that works in a 6509 will work in a 6509E.  The converse is not true.
VIP Super Bronze
As long as you use the same sup in the new chassis, the modules should work fine.
141
